biesseworks boring program - dxf import
1/4/16
tony Member
How to make a dxf file for boring in biesseworks
1/4/16       #2: biesseworks boring program - dxf im ...
alex
You need to setup layers in your cad software. See attached dxf file for example of the layer names and types. Your biesse works manual or help menu should have the dxf layers and how to use and set them up.
Also a quick way to see the layers setup correctly is to make a drilling in biesseworks and export to dxf.
alim_022877_BK.dxf
1/4/16       #3: biesseworks boring program - dxf im ...
Stuart
I recently had to something similar. I didn't think of RTFM but will make sure i do that if it is in there. I instead used google and found these links helpful, https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=U
TF-8#q=biesse%20dxf%20import%20video
