Biesse vacuum pod repair
1/12/16
Jeff Carlson
We have a bunch of vacuum pods that have been damaged and become unusable over the years. I would like to repair them but am unsure what type of substrate I should use to refill the voids. Bondo is brittle and doesn't adhere well to the phenolic pod. Is there a resin I can purchase that would be the best choice?
1/12/16       #2: Biesse vacuum pod repair ...
jerry Member
I would try silicone
1/12/16       #3: Biesse vacuum pod repair ...
Mark T
I have never had any problems with Bondo, but have also used the fast set two part epoxies you can get at the hardware chains. In either senario I always crate a "form" with doublesided tape and something like thin card board as a stiffener and let sit over night. Then just machine all edges flush and/or lightly file or sand.
Mark
1/12/16       #4: Biesse vacuum pod repair ...
B.H. Davis  Member
Website: http://www.curvedmouldings.com
I made our vacuum pods years ago out of 3/4" PVC from McMaster-Carr. They've taken a good beating over the past 15 years but I've kept them going by making patch repairs with PC-7.
PC-7 is a widely available two part epoxy similar to JB Weld but thicker.
1/12/16       #5: Biesse vacuum pod repair ...
Stuart
all of the above are good ideas. there are also a lot of aftermarket pods out there. BVC is the one i have seen the most at shows. See link.
Green BVC
1/24/16       #6: Biesse vacuum pod repair ...
derrek
We used a lot of Bondo in the past. I have also had good luck with Shoe Goo. Dry's hard but is a little flexible and very tuff
2/5/16       #7: Biesse vacuum pod repair ...
Mike McClaran
Website: http://www.greenbvc.com
Thanks Stuart.
Jeff,
You might save money making or repairing your vacuum cups. Or one phone call and you get Better Vacuum Cups in the next day or two that hold better and last longer. Stick to making cabinets and let BVC make the cups. That's why they call it a profession. Free shipping in the USA if you mention this thread.
4/26/19       #8: Biesse vacuum pod repair ...
sherrycnc Member
Website: http://www.cncsapretools.com
RicoCNC supply a range of Biesse vacuum suction pods
11/14/19       #9: Biesse vacuum pod repair ...
Sherry Zhao  Member
Website: http://www.cncsparetools.com
Biesse suction pods are mainly made of 4 parts, including base body, bottom white locating ring, black ball valve, and soft rubber seal. Usually, the base body is not easily damaged, but other parts are easy to wear and damaged. So if minor damages, you can try to replace these small parts. It is not hard.
