drills in mastercam
1/30/16
Dave Member
Website: http://www.builtins.com
I am posting closets to a onsrud panel pro with master cam and if the is a piece with a cam hole in it at the 0 part of y axis the drill says its exceeded its limit in y. I think the program is reading 0 at the router collet and not at the drills. How do I trick the program (mastercam) to exceed the y ?
1/30/16       #2: drills in mastercam ...
john
Does your machine use an offset for the drill block? is mastercam posting to that offset? What version of mastercam? The only time I would get an error about over-travel would be at the machine when it hits a limit switch.
Also mastercam may select a drill from your block that causes the machine to over-travel. If that is the case then just disable the few drills that cause over-travel. Mastercam will select one within range.
AS far as my mastercam is set up I can exceed the y all day long and it will still post a file.
2/1/16       #3: drills in mastercam ...
Snaglpuss
Aren't your axis limits a function of your controller and not of Mastercam or your post?
I can draw, program and post a part a mile away from my machine relative to its 0,0. I can post and load it and only then will the machine controller say "axis out of bounds or axis limit".
Can you edit your machine axis limits slightly? (Be careful).
Shift your piece on the table slightly?
