cutting Melamine wood using a cnc
3/3/16
anthony Member
hello all
hope your having a great day
i would like to ask if its possible to cut Melamine wood using a cnc ?
and if it make a good clean work?
any tips to achieve a clean Melamine cut
thank you in advance
3/3/16       #2: cutting Melamine wood using a cnc ...
Steve Member
For two sided, I use a compression bit. You need to be able to cut full depth in one pass for this type of bit. Clean cut both sides. Correct feed and cutter speeds are important.
3/3/16       #3: cutting Melamine wood using a cnc ...
Anthony Member
And is CNC Flat Table a must for this type of cutting? Sorry for this kind of question but i am still new in this field and i am looking to get all the information needed to start using a cnc thank you
3/3/16       #4: cutting Melamine wood using a cnc ...
I prefer a flat table router over a P2P, have both. We cut 40 to 60 sheets of 2 sided melamine coated particle board a day on a flat table, nested. Tool changer, & drill box are very desirable for almost any level of production. Compression spiral bits work very well, just run @ the feeds and speeds recommended by their manufacturers. We use Onsurd bits.
3/3/16       #5: cutting Melamine wood using a cnc ...
Steve Member
A compression bit is designed to have a upcut spiral at the end/tip of the bit and a downcut spiral about a 1/4" above that end/tip. The theory is the cutter ejects chips up when cutting the bottom and ejects chips down when cutting the top. A flat table (spoil board) is required for the cutter to slightly cut into when cutting in a single pass. Unlike saw blades, there is no downward thrust into the spoil board.
