3D Design
3/8/16
anthony Member
Hello Hope your having a great day
i would like to ask if any cnc flat table can produce 3d designs (hard wood or mdf ...) ? or there is a special cnc criteria needed to do so ?
thank you in advance
View higher quality, full size image (736 X 490)
3/8/16       #2: 3D Design ...
Can any flat table produce those designs? Yes, provided the software generating the code is up to the task. For small parts, or intricate designs, you might want to investigate ease of using fixtures with flat tables. You will want to have an aluminum or phenolic table with a grid pattern to concentrate vacuum underneath a custom fixture board for small, or odd shaped parts. I have used some software in the past that had the ability to take large amounts of linear moves in either the x or y axis and convert that into linear moves, plus arc commands on the x,z or x,y axis. This results in shorter programs, and increased processing speeds. Not normally an issue unless we are talking about a program that needs a full shift to complete. I am pretty sure that not all controllers are capable of this, but you may want to investigate arc interpolation capabilities using G18 G19 workplanes.
3/8/16       #3: 3D Design ...
anthony Member
Mike Thank you for your reply
i am testing the vectric aspire it seems that its easy to use .
i will be getting a flat table cnc i will use it for nesting and vertical drilling and routing and i would like to make maybe some 3d designs on mdf or hard wood
i would like to add if it possible to add pods to a Vacuum table ?
3/8/16       #4: 3D Design ...
Anthony,
I have a flat table machine with the phenolic type table with the grid pattern. I also use pods on occasion when I need to elevate a part for profiling, or reintroduction to the machine. The pods fit perfectly into the machined grids and access vacuum via ports in the table. They are handy, but hardly ever use them. Most of my parts that aren't held by the bleeder board hard kept in place using a custom fixture. I've made hundreds of them over the years out of scrap melamine. Usually for holding solid wood, or something very small.
3/8/16       #5: 3D Design ...
anthony Member
Thank you Mike Great advice
