Lock mitre joint
4/12/16
Conor Devoy Member
Website: http://www.devoy.ie
Hi all,
I'm always looking for new/better ways to do what I'm doing. We make a lot of our drawers out of 15mm birch ply with a blind dado. I'm attaching a picture of a cutter Titman tools used to sell for a lock mitre that can be done on a cnc. They have stopped for some reason, has anyone else come across something similar by another manufacturer. I can get a bespoke one made but would prefer something off the shelf. Thanks Conor
View higher quality, full size image (1416 X 912)
4/12/16       #2: Lock mitre joint ...
Jim Herron
I just bought one for a shaper from Freeborn Tool.
4/13/16       #3: Lock mitre joint ...
Conor Devoy Member
Thanks Jim, I had a look at Freeborn. They seem to be spindle tooling, I'm looking for a tool I can put into a cnc router. Thanks Conor
4/13/16       #5: Lock mitre joint ...
Jimherron
Might try southeasttool.com
4/13/16       #6: Lock mitre joint ...
DOM
Website: http://NAPLY.COM
PG 70
http://www.buputensili.it/pdf/BUP%204-5%20-%20CNC%20ROUTER%20CUTTERS.pdf
4/13/16       #7: Lock mitre joint ...
dylan bayliss
check out whiteside tool
View higher quality, full size image (1366 X 768)
4/13/16       #8: Lock mitre joint ...
Conor Devoy Member
Thanks for all your suggestions, as far as I can tell the Titman tool in my original post allows you to do both cuts while the pieces are stuck down to the CNC bed. I want to avoid having to do a second pass by turning the drawer side vertical on a router bench or spindle. Thanks Conor
4/13/16       #9: Lock mitre joint ...
DOM
No. the ones from BUP tool on page 70 are 2 tools. One does 45 male the other does 45 female. look closely at the profiles. Works good in a nest.
BUP
10/8/19       #10: Lock mitre joint ...
Conor Devoy Member
Hi Dom, just saw your reply now!
Thank you, I'll be getting onto my supplier tomorrow. Thanks again.
