CNC Pod and Rail
4/18/16
anthonyghattas Member
Hello hope your doing great
i am new to cnc and i am intrested in upgrading my carpentry
i would like to as if anyone used a pod and rail cnc for nesting melamine board ?
i am interested in getting a machine that i can use for both boards nesting and where i can make horizontal drill for doors ...
hope you can help me guys
Thank you in advance
4/18/16       #2: CNC Pod and Rail ...
Anthony,
You may already know that pod and rail machines are not designed for nesting. Typically they are used for vertical and horizontal drilling plus routing panels that have already been cut to size on a panel saw, or sliding table saw. Nesting is traditionally done on a flat table machine. I have a flat table machine with horizontal drills as well. The downside is that there isn't enough clearance to drill all 4 edges without elevating the panel. That requires pods, or a special fixture to elevate the part enough so that the bottom of the horizontal block clears the table. You could use a flat table machine for nesting, and if the table is large enough, you could place pods on an unused section for door drilling. If you have a good used pod and rail machine that your are looking at you will have to stop thinking about nesting parts into full sheets.
4/19/16       #3: CNC Pod and Rail ...
Thank you mike for the great advice
