Cnc Beginner
5/2/16
anthony Member
Hello all
Hope your having a great day
i would like to learn about cnc routers , which bit to use ,how to operate the cnc machine .
where can i find an online class , tutorials ,videos , pdf ...
thank you in advance
5/2/16       #2: Cnc Beginner ...
Kevin Jenness
As a recent convert to cnc routing I will say that I have found a great deal of useful information on the camheads.org site and the Vectric software forum. Both are quite active with help available from users of Camaster and Vectric products, but there is considerable info of a general nature as well. Vectric software seems to be widely used at least in the signmaking world and they have a lot of tutorials on their site. Shopbot also has a very active forum. There are a lot of videos of variable quality on Youtube, including some interesting ones from a solo furnituremaker named (I think) Andy Pitt. This forum is a great resource for answers to well focused questions. I hope to hear of other valuable sources from the more experienced people here.
Be aware that there is a lot to learn before you get productive with one of these machines. It helps a lot if you are computer savvy to begin with, particularly in terms of drawing programs. Training and setup from the seller of a new machine should be available to get you going and will factor into your decision to purchase. I bought a used machine, and the existence of the Camaster forum was a consideration that has proved out in the help I have received there.
5/2/16       #3: Cnc Beginner ...
Jerry Member
Shopbot has training videos on their site under the support dropdown
5/3/16       #4: Cnc Beginner ...
James Miller Member
Camheads and vetric!! I've been doing cnc work for 3 years now and would not be where I am without them.
5/3/16       #5: Cnc Beginner ...
Jerry Member
The videos I referred to give you basic information on the operation of the machine and designing parts not just a question and answer like on a forum
5/3/16       #6: Cnc Beginner ...
Joe
If you mentioned a geographical area you could swing by one of my shops to get some hands on time.
5/4/16       #7: Cnc Beginner ...
Anthony Member
wow so much to learn :D Thank you guys for this great help and guidance
i have 2 months before my holzher master pro 7018 arrives so i have to start doing my homework
5/4/16       #8: Cnc Beginner ...
mike  Member
Website: http://www.lustigcabinets.com
I googled the machine, it seems to be a rail and pod system. That is different than a vacuum table system. I would hope the company offers some setup and training. What software are you using.
5/4/16       #9: Cnc Beginner ...
Anthony Member
Yes its a pod and rail cnc and i will be using their own software Campus .Does bits change from one type of machine to another?
5/5/16       #10: Cnc Beginner ...
Jerry Member
Pod and rail cnc's are used for a different things than flat tables. The bits are the same but the units are meant to machine parts to size and shape and machine dados and drill. We have one of each and also a beam saw that cuts the blanks for the pod and rail.
5/5/16       #11: Cnc Beginner ...
Kevin Jenness
Anthony,
Beyond a general orientation to tooling types, feeds and speeds and understanding the mechanism and maintenance of your machine, you should probably concentrate on learning the software that operates it. You need to draw the parts, design the toolpaths to machine them and make the machine execute the toolpaths. Depending on what you are making that may mean using separate CAD and CAM programs plus the router control system, many of which are proprietary, some of which you can write and modify code for.
The Vectric CAD/CAM program I am learning allows for drawing, toolpathing and simulating the machining in a 3D view. It gives a pretty realistic idea of what the tools are doing and what the finished part looks like. If you can get familiar with that process prior to getting the machine you will be way ahead of the game.
