Post Production Output
5/25/16
Dale Nugent
We are a midsize custom home builder & custom cabinet shop in the Midwest, we have hired a professional cabinet designer to provide accurate and efficient information to our cabinet shop, we currently employ a person that runs the CNC program of KDC in the post production capacity.
What should be a reasonable output= Hrs/Job for a post production employee on an average 30-40 cabinet job?
5/25/16       #2: Post Production Output ...
Can you define post production a bit more?
5/25/16       #3: Post Production Output ...
Dale Nugent
more "Post Processing" actually; meaning this person takes the design (which is created in KCD software) and converts the information (through the KCD post processor {I believe the program converts the info to g code}) and sends it to be cut on the CNC router. This person also has to make sure that any custom parameters of the job are set properly to ensure accuracy of the cutting...make sense?
5/25/16       #4: Post Production Output ...
What CAM program are you using?
I don't know KCD at all, but for what I use, once the design or model is done, exporting the dxf files, nesting the parts and creating the cnc files is 15 minutes or less.
5/26/16       #5: Post Production Output ...
Dale Nugent
What program do you use?
5/26/16       #6: Post Production Output ...
For what?
Cabinet design?
Nesting?
CAM?
Looks like KCD CNC Commander will export G-code easily. Can they supply a post processor for your CNC?
