Frank,
I don't know if this is any different than what you have.
I have some emails from about 6 years ago when we came across this, our problem was the format wouldn't accept more than 99 parts so part 101 messed up the cutting instructions.
I think you need an AD file for the inventory sizes. The AD file can contain only one material type but can contain different size boards.
A-
Giben America AC File Format 1/1
The AC file is Giben's import/export file format. It contains the cutting
pattern data for one material. This is termed a JOB in OPTISAVE.
The file consisits of ASCII text, undelimited, fixed-field format with filename
extension AC (filename.AC)
Example:
0 1 2 3 4
01234567890123456789012345678901234567890
PARTICLE BOARD 1920110050024832125440
PARTICLE BOARD 192012002483201
PARTICLE BOARD 192013000614402
PARTICLE BOARD 192014010614404
PARTICLE BOARD 1920210010024832125440
PARTICLE BOARD 192022002483201
PARTICLE BOARD 192023000307204
PARTICLE BOARD 192024010614404
PARTICLE BOARD 1920310025024832125440
PARTICLE BOARD 192032002483201
PARTICLE BOARD 192033000614402
PARTICLE BOARD 192034020307207
In the above example, the first line is the HEADLINE and the subsequent lines
are pattern data lines. The first two fields MUST be the same on ALL lines!
Explanation:
HEADLINE
Character Position Field Description
1-15 material type (optional)
16-18 thickness (1/10 mm or 1/254 inch)
19-20 pattern number
21 record key = 1 for HEADLINE
22-26 board quantity
27-31 board length (1/10 mm or 1/254 inch)
32-36 board width (1/10 mm or 1/254 inch)
37 ABBA or headcut trim: = 0 for no or = 1 for yes
PATTERN DATA LINE
21 record key = 2 for headcut, = 3 for rip cut,
= 4 for cross cut, or = 5 for z-cut
22-23 part number
24-28 cut dimension (1/10mm or 1/254 inch)
29-30 cut quantity
