White Acrylic
5/23/16
Nick Cook Member
Website: http://www.cedarrivercabinetry.com
I'm using White Acrylic from Northern Contours in sheet form (.049 thick) I'd like to make panels that are 1.5 wide by various heights to use as thick end panels (applied ends). Would it be feasible to laminate the acrylic sheet to MDF using contact cement and then edge band the face 1.5 edge?
5/23/16       #2: White Acrylic ...
Jared
I can't think of a reason why it wouldn't work. The MDF might cup a little since it's able to gain & lose moisture over time, but your end panels are fastened to cabinets so it shouldn't be much of an issue. Not sure about edgebanding glue sticking well to acrylic though, but I've never tried that one.
6/5/16       #3: White Acrylic ...
Jason Scott
I might try running the sheet through the belt sander before you laminate the sheet and cut your edgebanding.
