Z offset values on a fanuc
6/30/16
Brent Member
I am setting up a 2006 Omnitech selexx pal with funac. My software tech wants me to locate the z offset values for each drill bit in the drill head so we can set the depth of each bit. Does anyone know where I can find it on the machine?
7/3/16       #2: Z offset values on a fanuc ...
Brian
I go through this a lot, where the person setting up the post wants you to find the information that they should have or locate themselves. but any ways, one way of doing it is to install one bit, in the corner if it is an L shaped drill bank and bore a hole and measure where it is in relation to what you programmed, the remainder are 32mm increments from that. That will get you started but really this information is avaliable to them as well. Sorry just my rant,
7/3/16       #3: Z offset values on a fanuc ...
I programmed a 3" square with a hole drilled dead centre to do this.
7/4/16       #4: Z offset values on a fanuc ...
I can't quite tell from the question, but you are probably looking for where each drill length offset is recorded? If so, it will be in your offset registry where all length offsets are stored. Probably below the spindle tools. On mine, the first twelve are occupied by my tools in the tool changer. My drills start at 21. Drill one =21 Drill two =22 and so on. They can actually be any number you desire, the offset is just a place holder. As long as the code calls the drill, or master drill and calls that offset, you are good to go.
