CNC bit Chipping -- 1 --
7/12
I have some trouble with 5/16 bit.
Somehow this bit is making cut which is chipped and clean when making dado cuts . That clean cut looks like it is for male dado, chipped cut looks like for female dado.
I am sending picture when it shows that some dados have clean cut and the rest of them is terrible chipping . It is the same bit.
Any idea what is happening ?
7/13 #2: CNC bit Chipping ...
If you have been reading posts here before, you should know that you need to provide more information. What kind of bit? Up spiral, down spiral, or straight. How many flutes? Feed and speed data. Did you ramp in the cut, or plunge vertically? Single pass? Just guessing, without any important information, it looks like a plunge cut, single pass where the two cleanest cuts were first and second in order. Rpm's too high, feed too slow so the bit got hot and chipped out the remaining cuts. That is only a guess. Another possibility is poor quality core on the board is contributing to the problem.
7/13 #3: CNC bit Chipping ...
Are both cuts going in the same direction. One looks like it is packing the chips in front of the cut and the other looks like the chips are behind
7/13 #4: CNC bit Chipping ...
As asked previously...
1. What type of bit? Up Shear, Down Shear, Compression, Straight?
2. Are the depths of the dadoes all the same?
7/13 #5: CNC bit Chipping ...
...if using a Compress bit and the depth are NOT the same then -
The shallower cut would be exposing the Up Shear section of the tool to the top melamine surfece, whereas the deeper dado would bury the Up Shear section and the Down Shear part of the cutting edge would leave you with a clean, non-chipping finish.
(Could not tell conclusively from the image, but depth could be different.)
BTW: What is the difference between a Male and Female Dado?
7/13 #6: CNC bit Chipping ...
This is 2 flute 5/16 down cut . dept should be the same .
Attached is picture of final product . Cut for male dado cut is clean and for female dado do chipping . Any idea ?
2Full_page_photo.pdf
7/13 #8: CNC bit Chipping ...
Hi Bob,
I agree with Jerry it looks like for some reason the female grooves are being routed in a different direction to the males. Either that or in 2 passes. Watch carefully when it's cutting and see if it's making 2 passes & which direction it's cutting.
Good luck.
Richard
7/14 #9: CNC bit Chipping ...
Bob,
What are the feeds and speeds you are running with this tool?
7/14 #10: CNC bit Chipping ...
Attached is picture of tool setup
View higher quality, full size image (496 X 573)
7/14 #11: CNC bit Chipping ...
What percentage of the feed rate are you running?
7/14 #12: CNC bit Chipping ...
100% and i can set that just in material property
7/14 #13: CNC bit Chipping ...
here is screen shot of property
View higher quality, full size image (992 X 291)
7/15 #14: CNC bit Chipping ...
your lowering speed seems really high. Could your bit have been damaged and just cut the dadoes after the tenons?
7/15 #15: CNC bit Chipping ...
It appears that your part is not securely held.
By that I suspect the part is vibrating up and down. There is usually an unusual noise (pitch) change when the part is being cut, if this is happening.
Also, poor dust extraction can exacerbate this as well.
Blaine
7/15 #16: CNC bit Chipping ...
Hi Blaine
No there is not any vibrations . If you check picture you will see that is on same sheet clean cuts and chipped . CNC 5/16 bit make clean cut for tenons ( blind dado ) and chip so much on mortise ( blind dado )
7/15 #17: CNC bit Chipping ...
Hi Bob.
Something else to look into, I noticed the cuts that are chipping are not parallel to X and Y, they are somewhat diagonal.
Try cutting parallel to X and Y, then try the diagonal cuts again. You may have some oscillation when the machine is interpolating the XY linear moves that is causing the chipping.
Blaine
7/15 #18: CNC bit Chipping ...
i check that ready .
7/18 #19: CNC bit Chipping ...
Put in a new tool, and try this.
Try cutting a hexagon approximately 10" in diameter, clockwise.
On the same sheet in the same program, offset the the geometry 5" or so to allow good visibility of the cuts, use the same geometry in the opposite direction, counterclockwise.
Is there any difference in the amount of chipping, and where it occurs in the 2 hexagons?
Please post a picture.
Thanks,
Blaine
7/22 #20: CNC bit Chipping ...
post a picture of the bit....
7/23 #21: CNC bit Chipping ...
We just seen the same thing
I grabbed an old scrap pc of melamine and cut that and it dont do it so we determined that we got a bad unit of material
1 --
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Galleries
Project Gallery
Sawmill Gallery
Shop Gallery
Shopbuilt Equipment Gallery
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
