Frog 3D
8/5/16
John Alves Member
Website: http://sevencontinents.com
Anyone knows how to create a G code parametric program for surfacing a block on a Frog 3D machine?
I would like to just change my block size and the program will surface that even if I change the size of my block and the diameter of my tool.
The attached file is what I came up with but when I put it on the machine it gave me an error about integers.
PARAMETRIC_SURFACING_ONE.pdf
8/9/16       #3: Frog 3D ...
Dan
Just a quick glance at the code....Any chance the Y0 value is causing the error. Does it need to be Y0.0 instead. Some machines (albeit few) need that decimal.
8/9/16       #4: Frog 3D ...
John Alves Member
I will try.
I did contact tech support and they have helped me a bit but even with the changes that they made it still not working. I'll keep at it on my spare time untill I get it.
Thanks again
8/9/16       #5: Frog 3D ...
Zak
Could it be the missing tool number? In the top parameters all you have this listed is #TOOL= (TOOL: 1.000 inches dia. slot drill), but there is no tool number after the =.
Shouldn't it be something like:
#TOOL=1 (TOOL: 1.000 inches dia. slot drill)
or
#TOOL=101 (TOOL: 1.000 inches dia. slot drill)
8/9/16       #6: Frog 3D ...
John Alves Member
That is one of the changes the tech support made but it still didn't work.
Good catch.
8/9/16       #7: Frog 3D ...
Zak
The only other thing that jumps out at me is line N11. Usually when something is in parenthesis, it's just a comment and ignored by the controller. Not sure if this is the case with your machine but it might be worth checking out. Also, some controllers don't accept five digit RPM's for the spindle speed. Instead or 14000 they will only take 14.
Just some thoughts.
8/9/16       #8: Frog 3D ...
John Alves Member
This is the latests. I still have to test it.
Tech support also sent me an alternative but I also have to test it still.
PARAMETRIC_SURFACING_ONE_2.pdf
PARAMETRIC_SURFACING_TWO.pdf
8/10/16       #9: Frog 3D ...
John Alves Member
Finally got it working.
Attached is the final working program
PARAMETRIC_SURFACING_ONE_3.pdf
