CNC with true 360 rotation
8/28/16
Thomas
We went to the IWF with hopes of purchasing a cnc that has the capability to turn stock. We do custom furniture and some cabinets. Approx. twenty five percent of our work is cabinet construction. The rest is custom furniture and reproduction mill-work.
One dealer advised me that they were the only one who could actually turn something on the cnc. Their machine would spin stock continuously while the router cut. I was advised by several other dealers that indeed, they could not go past 360 degrees without returning to zero. Camaster advised that they could turn a piece without going back and forth from 0 to 360.
Is Camaster and Legacy the only cnc that can turn a true 360? Should we consider straying from the 4th axis and just purchase an aggregate head with a flatbed cnc? We thought we had it figured out and then went to the show and left more confused. Thanks for the help.
8/29/16       #3: CNC with true 360 rotation ...
Gary Campbell Member
Thomas...
In many cases the ability to continuous turn a profile (vs the raster along axis centerline) is bases on two items. One is the cam software that generates the Gcode. The other is the torque and reduction specs of the rotary axis drive components.
Adding these two features to a production model rotary 4th axis would increase its price exponentially, which would reduce sales to almost nothing.
I build special purpose custom rotary machines for medium production requirements. Here is a video showing, continuous turning of a bezier curved surface: https://youtu.be/9bLnP9R7bE0
And here is a link to my video page that shows a few more rotary machines: https://www.youtube.com/user/Islaww1/videos.
Email: gcnc411@gmail.com for more info, specs and pricing
Gary Campbell
9/15/16       #4: CNC with true 360 rotation ...
John Alves
Have you heard of Frog 3D?
http://3dcutting.com/
9/16/16       #5: CNC with true 360 rotation ...
Thomas
John
I have not heard of Frog. I briefly looked at the web site you posted and it appears to be for foam only. Did not see anything about turning capabilities. From what I have seen, true turning capabilities are currently on custom machines only. We are still looking at our options. Thanks for the information. It is an interesting machine.
11/21/16       #6: CNC with true 360 rotation ...
Gene Member
Thermwood has a rotary device that is an add on option like the Frog machine. It sits on top of the table to add a 4th axis for turning table legs and can be removed pretty easily. It can continuously turn but only has like a 7 inch radius.
11/30/16       #8: CNC with true 360 rotation ...
stylecnc Member
Website: http://www.stylecnc.com/cnc-router/
1325 CNC router with 4 axis rotary
View larger image
