Alphacam
8/30/16
Paul Allen Member
We have Alphacam on 2 computers and when we send to the cnc from computer 1 every things works fine, when sending from computer 2 the cnc starts then freezes up. If we send it to computer 1 then to the cnc works fine.
8/30/16       #2: Alphacam ...
Keith Dillon
Sounds like you have the wrong post selected in computer 2.
8/31/16       #3: Alphacam ...
Marek Skotak
Website: http://www.cadcam-softcz.cz
Hello,
are u using RS232 and transfer over Alphaedit? Or transfer is over some USB Stick?
8/31/16       #4: Alphacam ...
Paul Allen Member
Thanks for your response. Computer 2 was working fine at one time, so I assume it would have the correct post.
A little more info, when we send the file from computer 2 (clicking Output NC) CNC will start and goes to Origin instead of start point, stops and gives Alarm 50 "Minor Radius profile"
If we open and send from computer 1 no problem. We have try all ways of sending, thru the output NC, over the network, usb.
8/31/16       #5: Alphacam ...
Marek Skotak
Could you please send me code from PC1 and PC2 on my email?
msskotak@gmail.com
9/1/16       #6: Alphacam ...
Mark
I would not assume and definitely verify the post first, it is not so hard to change it inadvertently.
Try from the home menu "Select Post" then view but do not change it.
If they are indeed the same, you could have any number of incorrect add ins selected, try looking at split nested sheets vs split nested program first.
