Question on biesse work sharp corner
9/8/16
Farmer Billy
I cant get the sharp corner to work . bringing in a dxf file and checking sharp angle and setting degree on the bit box. dont work . Also same trouble with finishing step have used this option in other software no trouble but his dont work. Any help would be apprecaite especially on sharp corner.
9/8/16       #2: Question on biesse work sharp corne ...
Wood Dust
Call biesse direct , they offer free over the phone biesse works help. They offer great support for their customer
I run biesse but have never used the biesse editor or any more than opening my files.
9/9/16       #3: Question on biesse work sharp corne ...
Dan
How are you importing the dxf, automatic with layers or manual (geometry only)?
9/9/16       #4: Question on biesse work sharp corne ...
Farmer Billy
With layer but just using open in the Biesse program Thank
9/9/16       #5: Question on biesse work sharp corne ...
Dan
Maybe, post the layer name in case there's something missing and we can try to take it from there.
Is your geometry lines, polyline, or rectangle?
9/9/16       #6: Question on biesse work sharp corne ...
Farmer Billy
They are rectangle thank
9/9/16       #7: Question on biesse work sharp corne ...
Dan
The layer?
9/9/16       #8: Question on biesse work sharp corne ...
Farmer Billy
we found the trouble one of setting in the gemotory was turned off Thank for help
1/17/18       #9: Question on biesse work sharp corne ...
Chevy
After your geometry is in biesse works,,you can select “sc” sharp corners,,,if you need help I can make a video for you.
3/20/18       #10: Question on biesse work sharp corne ...
Chev
just did a training class ,,,take a look at this photo that shows the "SC' sharp corner function
    • Better Vacuum Cups, Inc.
    • Country Saw & Knife
    • Charles G.G. Schmidt Co.
