getting started with "vintage" Komo
11/8/16
Jim Hart  Member
Website: robocutcnc.com
Hi, I recently bought a 1998 Komo Innova at auction and I'm trying to get it going. It looks like a very solid machine with a lot of useful life left in it.
The first obstacle is clearing the Fanuc "ZRN" errors that resulted when it was sitting around without power for months and the backup batteries in the servo drives ran down. I also need the procedure for resetting the ATC.
I have started it up and jogged it around. I was kind of surprised that I could casually jog it into an "extreme overtravel" alarm. Maybe that will go away when the encoders are reset?
It also seems odd that when I power it down the head slowly falls down and rests on the table.
Thanks for any help!
11/8/16       #2: getting started with "vintage& ...
If you don't find all you need here, look at cnczone or similar. There are millions of Fanuc controllers out there in the metalworking world and, other than wood specific issues, likely a lot more knowledge.
Also, did you google restoring parameters Fanuc (16? 18? 20i?) control? I did and got lots of possibilities.
Komo may be able to send you a copy of the manual if you have serial number.
This is fun stuff...
11/8/16       #3: getting started with "vintage& ...
Click on link below or copy and paste this link into your browser: http://www.kfasllc.com/memory_backup_restore_F1618.htm
Link
11/8/16       #4: getting started with "vintage& ...
Jim Hart  Member
My next stop after posting here was to post in the Fanuc section over at the Zone.
This ain't my first rodeo... :-)
As far as I can tell the parameters in the controller are still there. At least, there are values there and the jog speeds seem like they are in the ballpark.
I did manage to pry a parameter listing out of Komo for no charge, but the guy I talked to (Dean?) sounded like he couldn't wait to get off the phone.
I think all that's been lost is the encoder positions for the 3 axes plus the tool changer. I was hoping to find a homing routine in Fanuc BOP, but so far I've found nothing.
11/9/16       #5: getting started with "vintage& ...
Nothing odd about that head coming down when the power is off on a machine that old. Everything is loose enough for the ball screw to just rotate and it settles.
11/9/16       #6: getting started with "vintage& ...
Jim Hart  Member
So you don't think Komo built in any provision to keep the head from falling, just the friction of the ballscrew?
That seems a little odd. How do operators cope with this? Put a block under it at shutdown time?
11/9/16       #7: getting started with "vintage& ...
My Biesse Arrow does the same thing with the spindles. Fortunately everything is high enough that they don't hit the table.
11/9/16       #8: getting started with "vintage& ...
Jim Hart  Member
Okay, I guess I need to figure out a strategy for the "head drop" problem. Right now the tip of the bit that's in the spindle is making solid contact with the spoilboard. Luckily it's 3/8 diameter and old. If it were an 1/8 it would be in pieces.
11/9/16       #9: getting started with "vintage& ...
Our standard practice is to never leave a toolholder in the spindle after the machine is shutdown for the night. That being said, we have an older Northwood, the spindle, drill block and saw drop from lack of air pressure, but the Z axis does not drop or settle at night.
11/10/16       #10: getting started with "vintage& ...
Matt Krig Member
Email me your contact info, I have several versions from the early 2000's Funuc Komos
Batteries plus can make you any servo battery you need.
11/10/16       #11: getting started with "vintage& ...
Jim Hart  Member
I've been reading a procedure I found for "Mach One S and TG Solutions". I'm not sure if it's the right one, but I do know that when I push the button on the shroud to manually release the drawbar it doesn't do anything.
11/11/16       #12: getting started with "vintage& ...
Jim Hart  Member
Okay, I dug a little more and figured out that I needed to uncheck "auto-rotate" in the operator control panel to get the manual drawbar release and magazine rotate buttons to work.
There is an option in the "mode" window labeled "home". It's in the same list as MDI, memory, jog, MPG, etc.
Is this somehow used to home the machine at startup?
11/14/16       #13: getting started with "vintage& ...
Jim Hart  Member
Does this machine need to be homed at startup?
11/15/16       #14: getting started with "vintage& ...
Jim Hart  Member
Instead of the usual Fanuc display hardware this particular machine has a PC running a prehistoric version of windows (windows98, ha!) and a windows program called BOP-Basic Operation Package.
In the "mode" panel there is this option labeled "home", which I had been hoping might be used to home the tool changer, but so far I can't get it to do anything at all.
12/10/18       #15: getting started with "vintage& ...
Todd Zuercher Member
Website: http://pgrahamdunn.com
It is only that the batteries for the absolute servo positions are low. You will need to reset the home position for the ones that have gone flat. Komo has written procedures for doing this. You may have them already on the hard drive of the pc front end of the control, (On our newer Komo machines the pdf files were saved in a directory called "Machine CD") If you can't find them contact Komo and they can email the pdf instructions for your specific machine.
As to the head dropping, Air needs to be supplied to the machine for the counterbalances to support the weight of the head. Our Komos have check valves that hold air pressure in the cylinders that support the head when the machine is off and air is off. If the cylinders are leaking or there are other air leaks in the wrong places, the weight may not be held up when everything is off.
