flat vaccum table cnc
1/2/17
ANTONY JOHN Member
whats is the least size of panel, a flat vacuum table can hold, with spoil board,
while nesting.
i have to cut 400 x 40 mm panels, with one side taper.
thank you.
1/3/17       #2: flat vaccum table cnc ...
A lot depends on the vacuum pump horsepower, and the design of the table. If the parts are the same, sometimes a dedicated fixture is the answer. You don't need much vacuum if the fixture is well designed and the program is written with care. Hard to answer without specifics.
1/7/17       #3: flat vaccum table cnc ...
Lei Member
Website: http://www.dwd-cnc.com
I have been service engineer of cnc for 6 years,and i saw many clients who cut this kind panel. In my opinion,it depends on two things: first ,the type of the vacuum table--i suggest double-layer vacuum table with more than 86 vacuum holes.Second,the power of the vacuum pump, according to my clients, for 400*40mm panel, 7.5kw vacuum pump is ok(4*8 cnc)
View higher quality, full size image (497 X 680)
1/10/17       #4: flat vaccum table cnc ...
We union skin or tab for small parts, even that will be difficult on a 40mm wide panel. If you have a lot of these to do make a dedicated fixture.
