spindle repair
2/25/17
jim Member
I need to have the bearings replaced on a hsd spindle core. I just want to send out the core not the whole unit(I have already replaced the bad core with a new core). Does anyone have a recommendation of a good repair shop.
2/25/17       #2: spindle repair ...
Jim,
Did you get the new core from the machine manufacturer? I just replaced one last year and was given the choice of a rebuilt or new core. They also gave me credit for the old core I was replacing. Made the purchase easier. Regardless, I would just have HSD rebuild the old one, but that is just me. The spindles are too important to let anybody do it. I've been burned before.
http://www.hsdusa.com/
2/27/17       #3: spindle repair ...
Brian
Atlanta Spindle Services. Used them several times, good service, would use them again.
2/27/17       #4: spindle repair ...
Mark
I'm with Brian, Atlanta Precision Spindles.
I will send a spindle no where else.
2/27/17       #5: spindle repair ...
Johann Huck  Member
Website: http://www.themachinewarehouse.com
When rebuilding spindles. I would highly recommend sending the whole unit and not just the core. A proper spindle company will check the spindle for runout with the core inserted. If you replace just the bearings. You don't know if the old bearings wore out the core. This need to be checked to guarantee a good spindle.
Johann Huck
The Machine Warehouse, LLC.
704-839-6615
johann@tmwsales.com
3/10/17       #6: spindle repair ...
Yaakov
Buy new from china,copy hsd,same quality,less half price
They use 2 ceramic bearing from germany
6/2/21       #7: spindle repair ...
Anusha
Website: http://www.spintec.com.sg
Hi there.
Wonder if you have found the right one yet. Check out our website at www.spintec.com.sg and you may wish to review our catalogue as well!
Based in Singapore, our company is well-versed in the refurbishment of all make spindles. Hope this helps.
20191128_Spintec_Engineering_Profile_V16.pdf
20191119_Spintec__Catalogue.pdf
    • Biesse America
    • Template Services
    • Limtech Industries, Inc.
    • Palmetto Cabinet Doors
