cutting corrugated aluminum
4/26/17
Puzzleman Member
A customer wants me to cut a piece of aluminum with corrugated plastic in between the two sides of pre-finished aluminum.
Has anyone done this? If so, what type of bit did you use to prevent burring on the edges of the cut piece?
Thanks, JIm
4/26/17       #2: cutting corrugated aluminum ...
Paul Miller
How thick is the material and what type of equipment do you have to cut it?
I have cut aluminum with plastic sandwiched between thin aluminum with a CNC router. These sheets were only about 1/4" thick. We tried to cut it with our CNC plasma cutter and the plasma cutter would not cut through the plastic. I do believe a high powered laser will cut it the best.
Need more information.
4/27/17       #3: cutting corrugated aluminum ...
You did not mention thickness. I cut plastic with aluminum skins frequently with a single O flute tool. In my case Onsrud 65-033.
4/27/17       #4: cutting corrugated aluminum ...
Mike A
is it Alucobond like in the video below? If so call Vortex,Onsrud etc.. It is quite popular material and i am sure they have something spec'd for this.
https://www.youtube.com/watch?v=hEX8tBaFsKo&index=5&list=PLZYhcyQ82xdAzddLt1R8y-cFdUGtiXBp7
4/27/17       #5: cutting corrugated aluminum ...
Puzzleman Member
Sorry about the lack of clarity in my post.
It is 1/4" thick and I was planning on cutting it with CNC.
4/27/17       #6: cutting corrugated aluminum ...
Chuck Hicks Member
An O flute Spiral upcut would be the way to go or a straight flute O Flute will work also. I recommend blowing air on the tool and or mist to keep it cool .
View higher quality, full size image (6069 X 4105)
4/27/17       #7: cutting corrugated aluminum ...
Paul Miller
I agree with Chuck Hicks. I have cut panels like those you are talking about for a sign company. I have used a 1/4" up cut bit. It has been a while, I know we did not cut it too fast, 120 to 200 inches per minute. I also found that you have to mist the bit with water. I used water with a coolant from out tool room. If you go too slow, the plastic will melt and actually the bit will get too hot. I used High Speed Steel bits, nothing special. I worked the cost of a sharpening into my price.
