Alphacam VBA
5/25/17
ken Winningham
Need help with a VBA program. Need to fillet corners and cannot seem to figure it out. My understanding of VBA's are limited at best. This the portion of the geometry I need the four corners filleted.
Dim PanelGeo As Path
Set PanelGeo = drw.CreatRectangle(2, 2, Height-2, Width-2)
PanelGeo.SetStartpoint Height / 2, 2
PanelGeo. ToolInOut = acamINSIDE
PanelGeo.Seleceted = True
Any help would be appreciated.
Ken W
5/26/17       #2: Alphacam VBA ...
Gary B.
Ken,
I'm pretty well versed in VBA, but know nothing about AlphaCam.
What exactly are you trying to accomplish?
Does AplhaCam actually provide a VBA IDE? (Integrated Development Environment)
There are many things that could be wrong, but the IDE will help show you the errors.
I don't know what kind of object path is. If it is a class object, you'll need to use the new keyword, like this:
Dim PanelGeo as New Path
Also, you have some methods of objects being exposed and used. (Anything after a period is a method or property). One of these may be invalid.
I notice that you have a space between the dot and ToolInOut as seen below:
This would certainly break the code.
Also, you need to ensure that acamINSIDE is valid, and declared somewhere.
Furthermore, I'm surprised it would take the following parameter:
I would think that the parameter would look more like this:
PanelGeo.SetStartPoint (Height/2,2)
Lastly, VBA is a Case Sensitive. ThisSTring is not equal to ThisString
Good Luck, and post back if you need more help.
5/30/17       #3: Alphacam VBA ...
ken Winningham
Gary, Thanks for the reply, was finally able to sort it all out by looking at other examples and going line by line to get it to do what was needed. A programmer I am not...stubborn yes...but again it now works.
KenW
5/30/17       #4: Alphacam VBA ...
Gary B
Good to hear Ken, thanks for the response.
6/29/17       #5: Alphacam VBA ...
Marek
Website: http://www.cadcam-softcz.cz
Please send me your macro.
I can help you with this.
I hope :)
