Sharp angles in Alphacam.
8/12/17
Aleksandr Member
Trimming angles in Alphacam.
I can not solve the problem with constrained parametric angles in Alphacam.
For the drawing, I'm using 3d polylines. To draw the path of the tool by which it will rise and fall in the corners. Without use work planes.
I can not understand how to draw in the axes in work planes.
Are there other ways to indicate the path of the instrumen- tation so that it rises and falls in the corners. In Artcam there is a function "Trimming an angle" when engraving. In Alphacam, I have to manually draw the path of the tool on the corners. It turns out that something like a closed rectangle with sharp outgoing rays raised up to the desired angle in 3D polylines. It's very tiring to draw. In cconstrained parametric, these corners are stretched incorrectly.
How to draw such angles in axes in work planes or there is another way to solve?
To parameterize a workpiece drawing.
Thank you
View higher quality, full size image (1670 X 853)
View higher quality, full size image (999 X 736)
View higher quality, full size image (688 X 278)
8/14/17       #3: Sharp angles in Alphacam. ...
Marek
Website: http://www.cadcam-softcz.cz
Try i this way.
Video
8/22/17       #4: Sharp angles in Alphacam. ...
Ian Member
possibly do it with a profiled cutter and do the corners as a rest machining operation?
9/1/17       #6: Sharp angles in Alphacam. ...
steve tivey
is this still a problem, I may be able to help?
9/9/17       #7: Sharp angles in Alphacam. ...
Aleksandr  Member
Thank you so much.
I did not receive messages from the forum and I could not respond.
Video from Marek helped me a lot and I immediately solved my problem.
Thanks again to all of YOU for your participation and help !!
