Vcarve pro too slow cutting some shapes
8/23/17
Akram Member
Website: http://www.americanvisioncabinets.com
Hi,
i have a very strange problem, using vcarve pro, cutting some decorative panels, it cut at normal speed at some opening but at some other shapes it is running super slow, I am afraid it might caught the mdf on fire.
the super slow speed only at stars with 8 corners, please see attached
any help will be greatly appropriated.
Thx
View higher quality, full size image (1631 X 974)
8/23/17       #2: Vcarve pro too slow cutting some sh ...
Is the geometry consisting of 16 lines, or lots of very short line segments. If the geometry was brought in as a spline, then your machine is probably running a lot of code which takes time and that equals slow machining. Redraw the geometry with as few lines as possible and it will run better. Bad drawings equal bad code.
8/23/17       #3: Vcarve pro too slow cutting some sh ...
Now I see your drawing in another post of yours and it is easier to see. Draw the geometry with straight lines, then put a fillet where you need it. I'm guessing a bunch of short line segments make up the fillet radii.
8/23/17       #4: Vcarve pro too slow cutting some sh ...
Akram Member
I did not draw this panels, I downloaded as dwg from on line.
at this point I guess I have to see how to fix it.
Thank you
8/23/17       #5: Vcarve pro too slow cutting some sh ...
Akram Member
Thank you very much for the help
Node editing solved it, will run the file today and will see.Thx
View higher quality, full size image (977 X 854)
View higher quality, full size image (538 X 553)
