SPOILBOARD CUTTER
8/29/17
CRIS
I need a spoilboard cutter with 3/4 shank 2 in.dia.Cant find them anywere any suggestions
8/30/17       #2: SPOILBOARD CUTTER ...
Chuck Hicks Member
Cris,
We can certainly make it, but I think a 1/2" Shank would do just fine unless you are really removing a lot of material or running a very high feed rate. We have the 3/4" Shank but its in a 4" dia.
View higher quality, full size image (5312 X 2988)
8/30/17       #3: SPOILBOARD CUTTER ...
CRIS
I'm cutting mdf .4 in depth 600 ipm. Ive added another machine to the shop.I have one that's as described. but no manufactures id.
8/30/17       #4: SPOILBOARD CUTTER ...
dustmaker1
Do you need exactly 2"? Have you looked at the Amana RC-2180 , 2182 40mm and 60mm with 3/4 shank? Not specifically for spoil board but mite work. Or, the RC-2350 2" x 3/4 shank you could just use the bottom inserts.
Paul R
8/30/17       #5: SPOILBOARD CUTTER ...
CRIS
the one I have I purchased from cormatt when they were still in business,9 years ago. Its still going strong. Does anybody know who they were getting them from. I need to buy this off the shelf.
8/31/17       #6: SPOILBOARD CUTTER ...
Vortex sells 3/4" shank as standard.
Vortex spoil board cutter
8/31/17       #7: SPOILBOARD CUTTER ...
Why are you cutting so deeply? Over 3/8" cut?
9/1/17       #8: SPOILBOARD CUTTER ...
CRIS
Bill vortex 3/4 shank cutters are 3 and 4 in diameter, I need 2 in. Rich I make patterns and need to remove as much material as possible. a two in. diameter cutter works perfectly for what I do. I believe I may take Dustmakers advice and order an amana hogger and give that a try
