biesse rover 15 z axes origin of table set up
3/3/18
ozan  Member
does anybody help me how the set up Z axes origin of table, I just changed the vacuum pods they are 14mm height over the origin of table. can somebody guide me step by step. i attached Data/axes parameters below.
Ozan.
3/4/18       #2: biesse rover 15 z axes origin of ta ...
Dan
Ozan,
Do you use Biesse works and have a 'soft console' to run the machine? you could use the "jig thickness" to adjust your table height? You can set that with the variable in the "piece size" or in manual mode, use the jig thickness button on the soft console to adjust. Our is a flat table so we're re-setting this all the time. I may be wrong but thought the process was pretty much the same for pods.
3/4/18       #3: biesse rover 15 z axes origin of ta ...
ozan  Member
Dan,
i don't use biesse works, only machine controller NC410, it need to be done from machine controller.
3/4/18       #4: biesse rover 15 z axes origin of ta ...
Either Mark T or Chevy, both of who post on here regularly will know.
3/5/18       #5: biesse rover 15 z axes origin of ta ...
Chevy
anything you guyes need whats up
3/5/18       #6: biesse rover 15 z axes origin of ta ...
Chevy
either adjust your up limit and make -35 to positive value to the thickness of your pods or add your piece thickness and pod thickness when calculating depths,,
3/5/18       #7: biesse rover 15 z axes origin of ta ...
Chevy
i havent tried biesseworks on the NC410 controller ,,but im confident a biesseworks iso will work fine,,,,,working with a guy now to make a rover 24 run off of biesseworks,,,,can get a copy out to you in 24hours if you need
3/5/18       #8: biesse rover 15 z axes origin of ta ...
ozan  Member
Thanks all , Biesse technical support did it.
3/28/18       #9: biesse rover 15 z axes origin of ta ...
Biesse America  Member
Website: http://www.biesse.com
We have recently become aware that an individual, a former Biesse America employee, is obtaining copies of some Biesse software products in an unauthorized manner and is offering this proprietary material on Woodweb under the name of “Chevy” and website www.keysoftwareservice.com
PLEASE KNOW THIS INDIVIDUAL IS NOT A BIESSE EMPLOYEE, HAS NO RELATIONSHIP WITH BIESSE, NO LICENSE TO DISTRIBUTE THIS SOFTWARE AND IS NOT AN AUTHORIZED BIESSE REPRESENTATIVE OR DEALER.
Based on the above, please understand Biesse cannot, and will not, vouch in any way for the quality of Biesse products and/or services offered online unless they come from our authorized sales network. Further, Biesse will not offer any warranty or assistance on products not purchased through our properly authorized sales network channels.
THIS NOTICE IS INTENDED TO MAKE YOU AWARE OF THIS ILLEGAL ACTIVITY AND TO PROTECT YOU.
Thank you to all of our valued customers.
    • Limtech Industries, Inc.
    • Palmetto Cabinet Doors
    • Country Saw & Knife
