Preferred bit for 5mm line bore, in melamine
4/4/18
Matt
Suddenly we are having some chipping issues when line boring melamine (3/4"). It's mostly in white melamine but doesn't seem to matter what brand.
For drilling line bore all the way through (2 sided partitions, for example), we have used a V point 5mm bit rather than a brad point, since the brad points tend to chip the underside. Lately, even the two brands of V-point I have tried are chipping the UP side. The down side still cuts clean.
I've had this happen with brand new bits, and I have also swapped tool holders and collets to rule out a damaged holder.
The one thing I haven't tested yet is the rotation and feed speed (9000rpm, I don't recall the feed speed) but historically these have worked pretty well.
What bits are you guys having good results with, for full through line bore?
Thanks,
Matt
4/4/18       #2: Preferred bit for 5mm line bore, in ...
I recently made the switch to solid carbide bits.
4500 RPM 75 IPM
No more chipping.
4/4/18       #3: Preferred bit for 5mm line bore, in ...
Rich
Try changing the feed speed (faster).
also agree the solid carbide bits cut much better.
4/5/18       #4: Preferred bit for 5mm line bore, in ...
Chevy
vortex makes some nice bits,,,,
4/5/18       #5: Preferred bit for 5mm line bore, in ...
Chevy
keep in mind, ,,most cnc boring blocks (not independent boring machines) have a limit of 2.3-3.77HP mechanically, more often than none the plc limit is 4k rpm,,some newer machines you can push to 6k because of linear motor/drives ,,,keep it steady(slow and steady wins the race) ,,the drive and boring block assembly drive all your vertical and horizontal spindles and your grooving saw, with on one belt/ or cam,,if you are pushing that drive past what the manufacturer sets it at leads to a headache (7k service job) the boring block case is not easy to dissemble/reassembly(correctly)
4000rpm with some nice carbide bits
orange with orange
black with black
-Some words from Chev
4/5/18       #6: Preferred bit for 5mm line bore, in ...
steve
Brad point are designed to chip the bottom not the top, v point to chip the top not the bottom.
Why not both? Drill 1/2 way with a brad point finish with a v point. No chip out on either side (provided you're using sharp tools). No bit is going to not chip one or the other, that's not how drill bits are designed.
4/5/18       #7: Preferred bit for 5mm line bore, in ...
Chevy
weather brad or vpoint ,,pierce into the spoil board 1/16" will clear the melamine egg shell/plywood veneer, ,,if your concerned about protecting your spoil board,, the fishtail(reverse) type drill bits give you that 1/16" threshold ,,
5/21/18       #8: Preferred bit for 5mm line bore, in ...
Josh
I've had good luck using brad point and not going all the way through within a few thousands.Leave just a hair of material on the on the other side that either falls out or brush over it with your hand during assembly to remove.
