Biesse Works Variables
7/12/18
John  Member
I'm fairly new to CNC's but I've created a spreadsheet that allows me to choose files, quantity, and resize as needed (programs are parametric). This is all great but my library is huge because I have minor milling functions that I don't know how to control without opening the program and turning on or off the various milling functions as I need them.
I'm wondering if this can be done as a variable. I've made variables for location of my line bore but can't see how to turn on or off a milling function like a notch for base board molding at the bottom of my vertical.
Any help would be greatly appreciated. Thanks
7/13/18       #2: Biesse Works Variables ...
katz
read the manual ,its very detail
in bsw you have also the option to write VBs
its not so friendly ,but its very powerful
7/13/18       #4: Biesse Works Variables ...
John  Member
you must have a different manual than me....mine is definitely not detailed. It gives one example of creating a rectangle with variable dimensions. But it does not say how to Enable the Milling, or Disable the Milling which is what I'm trying to figure out.
Any ideas?
7/13/18       #5: Biesse Works Variables ...
Jarvis
See it in the manual it goes over "if than" statements.
You can write something like if "lpx>23 than do this"
7/14/18       #6: Biesse Works Variables ...
Dan
I haven't done much in the vb format but the basic statements are in your insert menu under instructions.
One way to think about it may be to set up the variable millings as macros and load them if the variable condition is met.
An example:
Create a pocket with the GID=pkt
Save the program as a macro (see manual) and call it PKT1
Create a program & insert a variable (we'll say Notch) and give it a value of 1.
Draw geometry for the pocket and name it "pkt".
On a line below the geometry - insert - instructions - condition 'if'
Set the condition to notch=1
Replace the highlighted 'add the code here with
PKT1 GID="pkt"
You can test that by flipping your variable to 0 and back to 1. Should work
7/14/18       #7: Biesse Works Variables ...
John  Member
If statements....I'll try it, haven't done much with that stuff in a while will have to brush up on it. Do you think it'll work right in the code below the drawing, or I have to use a Macro?
Thanks for the help.
7/14/18       #8: Biesse Works Variables ...
Dan
Yup.
It'll work.
one operation, two or ten if you want.
If_else.pdf
7/14/18       #9: Biesse Works Variables ...
John  Member
Thanks Dan that looks perfect. I'll play with it Monday. Appreciate the help!
7/15/18       #10: Biesse Works Variables ...
katz
not only if..
also can make loop
for...next
while
math calculate like sin cos..
and 3d work
its real powerful but not easy operate
7/15/18       #11: Biesse Works Variables ...
John  Member
Thanks Katz, I'll see if I can get the if statement working before I dive deeper.
    • Limtech Industries, Inc.
    • Palmetto Cabinet Doors
    • Country Saw & Knife
