Material For Lattice
8/4/18
Rob Member
looking for an exterior material that could be painted and strong enough to make a lattice panel for a balcony. I have attached a picture of the lattice panel. Thanks in advance
BRENT_TAYLOR._TOP_BALCONYpdf.pdf
8/5/18       #2: Material For Lattice ...
Eastern White Cedar, Red Cedar, Red Grandis have exterior applications that are suitable for that project.
8/6/18       #3: Material For Lattice ...
dconti Member
1" or 1 1/4
exterior mdf is the way to go with a good solid wood cap is the way to go, try to make that for $70 material cost. Prime it and let the painter finish it with everything else
8/6/18       #4: Material For Lattice ...
Sheet PVC
8/7/18       #5: Material For Lattice ...
Rob Member
I thought about the Extira - which is exterior mdf - I do not think it will be strong enough in the center of the "X". I made a sample out of plywood and it broke when put under slight pressure. I think even when the top and bottom cap are installed it will still not be strong enough?
Where can sheet pvc be purchased
8/8/18       #6: Material For Lattice ...
A plastic supplier.
AZEK makes it.
8/31/18       #7: Material For Lattice ...
Russell
MDX
