2 piece mdf doors
8/13/18
Steve Member
For those who make 2 piece insert panel mdf doors, what has been your assembly method? What have you done to keep pressure on the panels where they contact the rails while the glue dries?
8/13/18       #3: 2 piece mdf doors ...
Bill Member
Do you mean 5 piece?
8/13/18       #4: 2 piece mdf doors ...
Billy Owen
correct me if im wrong but typical doors are 2 stiles 2 rails and a panel?
8/13/18       #5: 2 piece mdf doors ...
EDDIE
I think he's talking about, cutting out a like a picture frame. Then adding a panel from the back. Maybe?
8/13/18       #6: 2 piece mdf doors ...
Ken
We make all panels fit tight and from the front and not the back. With the tight tolerances on the Cnc we can get them tight enough that we don’t have to apply any pressure. Light bead of glue set in with a mallet and block of wood and on to final sanding and finish.
8/14/18       #7: 2 piece mdf doors ...
Steve Member
Yes, we are cutting out the center and inserting. When you insert it from the front do you need to apply any putty or anything at the seam of the panel and rails/stiles before finishing? To stop the paint from cracking?
8/14/18       #8: 2 piece mdf doors ...
ken petrunick
Website: Ken Petrunick Custom Cabinets Ltd
No, if you machine them tight enough you should have no problem.
8/15/18       #9: 2 piece mdf doors ...
Matt
How do you deal with the radius in the corners from the main cutter on the frame?
Even if you clean it up with a 1/8" cutter, seems like you'd have to have at least a small roundover on the center panels to get the corners nice.
8/16/18       #10: 2 piece mdf doors ...
Steve Member
Well it’s easy enough to put a 1/16 radius on the panels.
