Omnitech error code
11/6/18
Gary Gossling Member
Our 5x10 Omnitech will throw and error code the says "single phase error" on all axis. It will do it randomly and without warning. We shut down and restart and it is fine until next time. I have checked the main wire connections where power comes in. It was originally wired 208v and we converted it to 440v by changing connections on it's transformer. That change was made about a year ago with no problems until recently. Any ideas?
11/11/18       #2: Omnitech error code ...
Maurice Member
Its possible that you are briefly dropping a leg of power, the only why to know for sure is actually put a monitor on each line, there are companies out there that you can rent a line monitor and it allow you to run a actual chart on each phase.
https://powercet.com/home/power-monitoring-equipment/p-ower-monitoring-e
quipment
Something to check out but you could simply start by going through you electrical circuit and tighten all connections in the circuit.
12/10/18       #3: Omnitech error code ...
Todd Zuercher Member
Website: http://pgrahamdunn.com
Another possibility is that you may have a servo cable failing (causing a short). I've had to replace most of the cabling on our two Omitech machines. I'd suggest opening the cable chains and inspecting the cable insulation.
