cutting formica sheets
11/23/18
ag Member
hi all
hope your having a great day
i own a nesting cnc table and i have a project that requires to cut formica polyrey
in diffrent shapes
can i any one give ne direction to do so
thank you all for ur help
11/24/18       #2: cutting formica sheets ...
I have cut Formica on the cnc for a few jobs. If you are cutting rectangles it is faster to work on a saw. For more complex shapes the cnc works well. I used a 1/8" spiral down shear bit at 600 ipm. There is a chance that a piece will lift off the table so I stand by with masking tape in hand. Also the spoilboard has to be flat and clean. If not flexible sheets like HPL will lift and you will not get complete cuts when the bit travels over a groove in the spoilboard.
If you are planning on inlays into laminate, that is a different story. I have done that will a 60 degree bit cutting the male inlay face down and the female face up. The cutting depth has to be tweaked to get a perfect fit.
Small pieces of laminate are better cut when they are adhered to the spoilboard with releasable spray adhesive.
I hope this helps.
11/24/18       #3: cutting formica sheets ...
james e mcgrew Member
I have done some inlays requiring tight fits, i will adhere the plam to a sheet of melamine with light adhesive, then cut with a .125 downshear, on the inlays i cut male first and female last, so i can adjust fit.
View higher quality, full size image (1170 X 780)
View higher quality, full size image (1600 X 1064)
11/24/18       #4: cutting formica sheets ...
Ag Member
Thank you all for your great help
I am doing sonthing like that
Its my first job like that any recommendation
Thank yo all
View higher quality, full size image (402 X 568)
11/24/18       #5: cutting formica sheets ...
Ag Member
By like that i mean working with 2 colors toghether
