I purchased a 2012 SCM S15B used with really low use on it. We are busy setting up for the SCM tech to set up the machine in early May. I am finding it difficult to gather information I need to give to Mozaik for my post and wondered if anyone here would be willing to help me out.
I am sure all of this can be tweaked when we integrate and test, but here are the details I need specifically as it relates to this machine. (it has the standard 7 position drill and a 10 position atc)
1. Gcode Output - inches or MM?
2. Tool touch off - top of material or top of spoilboard?
3. Z value output - out put Z values as negative or positive values?
4. Need a diagram for the drill head - guessing this needs to show M-codes for both axis's and the tool position numbers?
I have also been looking for some type of user manual for Xilog Plus. If someone has a PDF file of this and is willing to share that would also be very helpful.
Lastly, If any of you use this era machine and Mozaik together, I would like to know if you have also installed the CNC Operator at the machine. I know it isn't "needed", but it sure seems like not having the machine operator need help from the office for remakes, etc has it's advantages.
Thank you in advance!
