Advice on bit for cutting a 3/8" x 3 1/2" deep hole
5/31/19
jeremy
We have a need to drill a 3/8" x 3 1/2" deep hole in solid pine. This will be a blind hole, not through drilled. We have a Biesse Rover
B FT. What do you guys suggest? Would be a lot of holes, around 3000 total.
5/31/19       #2: Advice on bit for cutting a 3/8&quo ...
Using a spindle or a drill block?
I'd tend to use the spindle because it's quieter.
Long brad point drill bit. Feeds and speeds as per experience - maybe start at 4000 RPM and 75 IPM. Retract every 0.75 or so?
5/31/19       #3: Advice on bit for cutting a 3/8&quo ...
jeremy
We have spindle and drill block but figured we would need to use the spindle for the size and length.
