Cabinet Vision Labeling
6/5/19
Bob Member
We are looking at switching to cabinet vision
with S2M to manufacture closet parts.
One question I have not been able to get sufficiently answered concerns labeling.
When parts are bored and cut from the "back side: CV flips them 180 degrees.
(its a closet thing :-)
How is the operator infomed he must turn the label 180 degrees?
Anyone doing there own labeling using the info in the databases?
If so where would I find the orientation of the part?
6/5/19       #2: Cabinet Vision Labeling ...
Derrek
Website: http://www.closetdr.com
We use cv on our Rver S aitoload machine. Cv wrote a special post for the 6 sided machining operations. Our label has a dot on it that also shows on the computer screen. You place the label to match orientation on the screen. Originally it caused a little confusion with the banding circle. We turned the size up on the edgebanding so there is no mistaking it. We also rotated our computer monitor 90 degrees which made the picture on the screen 3x the size. We use a 3x2” label. Label material is vinyl with removable adhesive.
If I have time I’ll shoot a video tomorrow and post.
6/5/19       #3: Cabinet Vision Labeling ...
Bob Member
Thanks Derrek.
I would really appreciate that.
6/6/19       #4: Cabinet Vision Labeling ...
Derrek
My label it set up
Label It set up
6/6/19       #5: Cabinet Vision Labeling ...
Bob Member
Thanks!
I think we can make that "clock" a bit bigger we can make that work.
Even though we are on the east coast we use the exact same label from Able Label.
I have used others but had inconsistency in the removability of the labels.
Never had a problem with Able.
Thanks again for sharing.
    • Country Saw & Knife
    • Charles G.G. Schmidt Co.
    • Biesse America
