Rover Wasting Air
9/5/19
Bob
We just installed our new Rover A and could not be happier with the machine and its performance.
However, there is one quirk that bothers me.
Once a sheet is done processing and waiting for the ok to unload, it opens 2 air jets that clean the sensors on the offload side of the machine.
If you leave leave the machine in this mode for 5 minutes it will pretty much drain our 125 gallon air tank.
Anyone else with a Rover unload have this issues?
I was told by Service that when the side stops on the table come up they activate the blowers.
Seems like they could tie them to the offload table sides that move forward so they would not come on until the actual unload starts.
Did not happen that often, but enough that we had to up our screw compressor for 10 to 15HP.
Hard to keep on my guys about lising for leaks, when the machine wastes so much.
I tell them that sound is money escaping :-)
9/6/19       #2: Rover Wasting Air ...
mike
if it is out of warranty hire u an industrial electrician to wire it the way u want it to operate. most of the time they just swap wires or add extra wires to make work. i have a multicam & had several things wired to operate like i needed it to. & yes compressed air can get expensive.
9/6/19       #3: Rover Wasting Air ...
Check with a pneumatics supplier - you may be able to get some kind of timed valve that could cut the flow after a predetermined time.
9/6/19       #4: Rover Wasting Air ...
Bob
Looking to other Rover owners to see if they have the same issue and if so, how they solved it. If Biesse solved it, they did it on their own or they just live with it.
Don't know if I am the only one concerned about this. Maybe I should just grit my teeth.
I know I can re plumb the air lines but I don't want to void any warranties. If it goes as far as needing additional logic controllers (arduino or such) we have the capabilities. Should be an easy fix.
But Biesse is uber strict on what you can change on a machine.
Support blew me off on my concerns.
Got to say, they are not much for feedback.
Still, can't be happier with my decision to purchase the machine.
9/9/19       #5: Rover Wasting Air ...
cabinetmaker
Rover S with unloader/conveyer. Put some regulators on then and dial it down. No need to drain the shop for sensor bursts of air
However, we are getting ready to put the doweler, bander and the rovers on their own compressor to combat the shop polishing and shutting down the bander or the rovers tool change
I put blow nozzles on the doweler for the bed to be clean it’s not blowing full blast
I have an Akron and an idiot installer told me the broken air line in up in the end trimmer was suppose to be losing that hard. I signed him off and told him GTFO. Told me the glue premelter wasn’t for a shop my size. So didn’t teach my guys how to use it.
Anyway we were able to not put the other compressor in exclusively for the machines once we found that air hog of a leak, at least not right away
