Though Bore with Bradpoints?
9/24/19
Bob
Anyone (or everyone) through boring melamine with bradpoints?
Rover A flatbed.
9/24/19       #2: Though Bore with Bradpoints? ...
All the time as long as the spoilboard is in good shape.
9/24/19       #3: Though Bore with Bradpoints? ...
You only need thru bits if you own a pod and rail machine or if you need to drill holes that are right in the split if you have a twin table router. Spoilboard prevents blow out.
9/24/19       #4: Though Bore with Bradpoints? ...
We do. .038 over bottom of the material leaves a tiny center spot and round score from the knickers in the spoil board. Clean both sides and doesnt leave the spoil board full of holes.
9/24/19       #5: Though Bore with Bradpoints? ...
Bob
What feed speed at 6000 rpm are you using?
9/24/19       #6: Though Bore with Bradpoints? ...
50 to 100 ipm depending on the diameter.
