Biesse Rover 24 Editor Software
11/18/19
Darryl Member
We run an older Biesse Rover 24 CNC which we program using Biesse's Program Editor software. I am looking for a code example of routing a sloped slot. As an example routing a 100mm groove but starting at 3mm deep and ending at 10mm deep. I have no problem programing a groove all the same depth but am looking for an example where the depth chances from the starting depth to the ending depth. I know it's old software but hoping there is someone that is familiar with this software programming.
Thanks,
11/19/19       #2: Biesse Rover 24 Editor Software ...
Mark T.
In your start machining (green light) put a very shallow depth ( .1 mm - example), in your first geometry line, in addition to your X or Y coordinates, place an Incremental command in the Z field the amount you want to ramp down. Type a capital letter I , then the value of the finished depth. If you wanted to go 10mm deep it would be ZI10. I actually place an equal symbol between the letter I and the number value to aid in proofreading the code ( ZI=10). Either will work. Hope this helps!
Mark
11/19/19       #3: Biesse Rover 24 Editor Software ...
Darryl Member
Thank you Mark, that's what I was looking for. I knew to add a Z value and when I did it moved to that exact height, also the machine is a bit confusing as when you give Z a positive value it goes below the bed. I had it working using Z=-10 which ramped it down to 10mm above the bed. Adding the "I" for increment is a much safer way to go. Thanks Mark
