Commercial Kiln Drying
Thermocouple calibration
7/28/13
DryKilnsman  Member
I'm interested in calibrating thermocouples in the kiln. Some are the RTD type, but most are type 'J' wire made up at the ends (tightly twisted wires) with crimp fittings and heat shrink tips. Will be using a dry well calibrator with zero set at 32 degrees and span set at 160 degrees. Can this be done at the opto22 module in the IO panel using a made up pig tail approx. 6' in length or is it necessary to take the readings from the TC tip in the kiln? Does it really matter what the length of the TC wire is to the tip from the IO panel as some will be 200' to 300' long? Or is the signal just relayed to the module with no loss of accuracy? The kiln has 30+ TC's including the wet bulbs. Any other thoughts covering zero/span calibration would be appreciated.
8/5/13       #3: Thermocouple calibration ...
GeneWengert-WoodDoc
The wire length is important. That is why we use a three wire system, as this cancels out the wire length.
Calibration is not too important if the DB and WB are both off the same amount. So whenever possible, .calibrate them together.
Thermocouples in commercial lumber drying equipment are seldom calibrated as there is no easy way to adjust them and they are seldom off far enough to make a difference, assuming all connections are good. Once installed, thermocouples do not age or drift off of calibration. The biggest issue is the measuring equipment and that requires a commercial calibration.
However, as mentioned, if DB and WB are both 1.3 degrees too high, it is not an issue. So, as a first step, take the wick off the WB and make it a DB and then see if you get the same exact temperature as the nearby DB. Fans direction is important...always measuring entering air when doing this calibration.
8/8/13       #4: Thermocouple calibration ...
Henco Viljoen  Member
Website: http://www.tskilns.co.za
The Doc is right. Another important thing when using thermo couples is using the right cable, with preferably no join between the TC and the instrument reading it. TC read milivolts, any change in resistance, whether a join or incorrect cable type as well as length of cable affects the reading. You can calibrate TC with your multimeter. See the link below for mV reading at Temp. Personally I don't like using TCs. A PT100 is more accurate and robust.
Table
8/8/13       #5: Thermocouple calibration ...
GeneWengert-WoodDoc
I also prefer resistance bulbs.
Calibration of t/c is very difficult as getting the precise measurement of the calibration liquid is very difficult. In other words, DIY absolute calibration is usually not possible.
