Commercial Kiln Drying
White oak color
12/7/14
Jerry
I have a piece of white oak that has stripes running across the width of the board. They are not consistent with stick spacing as you can see and the stripe goes clear through the board. The customer says that when coated with poly or stain these stripes pop out like stain. I've never seen this before. Thoughts?
12/8/14       #2: White oak color ...
Looks like burnish marks to me, from the surfacing machinery. Who did the surfacing?
12/8/14       #3: White oak color ...
Jerry
I did not show the photo of the SLR1E but the markings go all the way through. The customer also claims to have seen this in other lumber from a different supplier. I believe it's something naturally in the wood but looking for a confirmation.
12/9/14       #6: White oak color ...
1. Who surfaced the lumber? I can see mill marks on the surface.
2. Has it been properly sanded? 120 grit minimum.
3. Is there some one with lots of real shop/lumber experience looking at these boards?
4. Sticker stain (look it up) can go all the way thru a board, but it is rare to see stickers close to each other, so was this lumber from a reputable vendor that knows how to dry lumber?
5. SLR1E has nothing to do with the complaint or conversation - is it a red herring?
You need to supply much more info and do a little more research before anyone on an internet forum can offer much help. Without lots of context, your questions will just flop there.
12/9/14       #7: White oak color ...
JeffM
I'm curious how you know it goes all the way through without sanding or surfacing it. Run a piece through a wide belt sander and then check it. Millmarks will pop out like crazy when stained or just finished. Is your customer prepping the boards before finish??
12/9/14       #8: White oak color ...
Jerry
Ok guys here goes.
The piece you see in the photos is 36" long. It is 5/4 white oak already S2S at 1 3/16". The reverse side has some skip on it.
I know these marks in the board go all the way through because I ripped an edge and on the edge I can see the marks in the interior of the board.
It is not sticker stain because there are about 10 of these stripes on this 36" piece.
We dry 7 MM feet a year and never saw this before.
The surfacing was done on our Newman 282 EQ3 and its hit or miss at 1 3/16". There's no issue there.
The customer finishes to size and sands the stair tread before it's sold.
The consumer claims these marks pop out after staining or applying poly.
A couple points to know.
1 this is not a huge problem for us. We have only seen this in a few pieces.We are just trying to find an explanation for this.
2 Our customer has also seen this in some kd lumber from another supplier.
3 I believe it is something natural in the wood.
Thanks for looking guys.
12/10/14       #9: White oak color ...
Gene Wengert-WoodDoc
What we have here is something that i see only once every three or four years. That is, it is very rare. Most people have never seen it, or if they saw it, did not know what it was so forgot about it.
This is unique to white oak. It occurs in the tree and not after harvesting, sawing or drying. It shows up most clearly after drying and planing.
So, what is it caused by? It is caused by a fungus, somewhat like blue stain, but in this case is dark. Somewhere in my notes I do have a name for this fungus, but it did not pop up right away when I looked...sorry.
12/10/14       #10: White oak color ...
Jerry - I meant you no disrespect in my earlier post. I just was unsure of your level of experience. Turns out you know what you are looking at.
But....it looks like you may want to buy back any lumber with this 'defect' and then sell it at a premium for its rare and unique appearance. Lemons> lemonade!
12/10/14       #11: White oak color ...
Jerry
Ha ha. We told our customer he should be paying a premium for our tiger striped white oak.
Thanks for all your input.
