Commercial Kiln Drying
sample ovens
2/8/17
Eric Emrick
What is the best type of oven for drying kiln samples?
2/15/17       #4: sample ovens ...
John S  Member
I believe most people use a microwave oven, if I'm not mistaken.
2/24/17       #5: sample ovens ...
Gene Wengert-WoodDoc
The best is one with an internal fan and a digital temperature sensor.
7/20/17       #6: sample ovens ...
Larry Sherrer Member
A simple lab oven works great. Size according to your needs.
https://www.mcmaster.com/#3258k21/=18l0ok1
7/23/17       #7: sample ovens ...
Gene Wengert - WoodDoc
Incidentally, we do not dry samples in the oven...samples are 24" to 30" long. The small pieces which are about 1" along the grain, full width and thickness are called moisture sections. Without a fan, a small oven will be hot on the bottom where the heating element is located,msometimes too hot, and cooler near the top giving weird weights. You cannot mix different sections in the oven, as the wet ones will initially give their moisture to the dry ones.
