Commercial Kiln Drying
Sap Stain In Cypress
2/28/17
Vic
I've never dried cypress before but have some coming. But the logs have been cut for quite some time. Should I be concerned about sap stain, or blue stain?? As SYP is prone to stain??
Thanks,
3/9/17       #2: Sap Stain In Cypress ...
Mitch Suber  Member
Website: subercustomshutters.com
I use a lot of kiln dried cypress, and I have never had any issues with sap causing problems. But I either prime then paint, or I apply a clear finish. I have stained one order using a exterior type oil stain, and did not have any problems, or none that were specific to cypress. I have seen on occassion where there was some mildew type surface stain present, but not that much. Sawing and shaping usually removes that. My concerns with cyress usually are due to the drying causes a lot of splits and cracks, and grain separation during the working process, especially in the thicker 6/4 range. If you are new to using cypress, be aware that often cypress may arrive wetter than most other woods. At least in my experience. Keep the moisture meter handy.
7/23/17       #3: Sap Stain In Cypress ...
Gene Wengert - WoodDoc
The amount of sapwood in cypress is very small, so it is rare to get much sapwood in the lumber. Hence, sapstain, also called blue stain, which is caused by a fungus, is rarely an issue as cypress lumber is all heartwood. SYP is most sapwood, so we see a lot of stain.
