Dust Collection
Subject: Re: Is This Enough DC?
Is This Enough DC?
10/5/13
Joe Wood  Member
Website: http://woodsshop.com/
I've been having a problem with little freckles on the planned surface of clear wr cedar, caused by the shavings getting trapped under the rollers. I can see the shavings dancing around on the table as the stock goes thru. Maybe I don't have enough D collection on this Powermatic 15?
The D Collector is a 2 Hp 1 Ph, 230 V, hooked up to the planer with a 15' long 4" clear flexible hose with the copper wire running around inside it, which I've grounded to both the DC and planer.
do I need more airflow, a bigger collector? Could it be the chip breaker height, or that flexible hose?
10/6/13       #2: Is This Enough DC? ...
Carl Hagstrom
Joe
Your post triggered my memory of a few Knowledge Base articles we have that cover the issue you describe
You may fine the first three links in the list found at the link below helpful. If so, let us know the outcome.
Carl Hagstrom
Systems Administrator at WOODWEB
Knowledge Base Arcticles
10/6/13       #3: Is This Enough DC? ...
Joe Wood  Member
Yes I've read those threads Carl, even participated in one or two.
I've been trying to find a solution, just wondering if my collector might be the problem as nothing else I've tried (grounding the hose) has helped.
10/7/13       #4: Is This Enough DC? ...
JeffD
The problem is probably not the size of your collector, but that your choking it! Flex hose should be kept to a minimum of say a couple feet to connect your machine to your duct work. Running 15' of it is WAY too much! Also 4" hose is probably not adequate for a 15" planer. I would move it up to 5" or even 6" if you can.
Even a cheap offshore 2 hp collector should be able to do the job fine as long as your only collecting from one source at a time. You just need to set it up properly:>)
good luck,
JeffD
10/9/13       #5: Is This Enough DC? ...
cabinetmaker
If you will take the y off the dust collector and add a 6" starter collar or bell mouth you can really ramp up the collector. Jeff is right though. You need to get away form the flex.
These guys are great and supply us with fittings and collars.
Air Handling Systems
10/10/13       #6: Is This Enough DC? ...
Mark Koons Member
Joe,
I'm, no dust collection expert, just another isolated woodworker trying to get a sense of what is effective.
I have, however, read the material on several sites including the invaluable but nearly unendurable Bill Pentz-generated content. I accessed it through a link on the ClearVue site. You could also Google Bill Pentz. The whole body of information pops right up. Pentz knows his subject better than any other researcher/teacher I've encountered though he desperately needs an editor and website designer.
My hunch is that your equipment would be satisfactory if you would eliminate that 15' of 4" hose which is unbelievably dirty aerodynamically. Replace it with a shorter run of well-sealed smooth duct with no 90 degree bends.
If that doesn't produce the results you need, increase airflow through the chip path between the cutter head and dust pickup by either drilling air intake holes (who wants to mutilate their machine?) or by re-spacing flow-restricting planer covers. Maybe using longer bolts and stacks of washers to mount one of your planer's panels would improve air flow to the necessary degree.
Good luck. Keep us informed of your findings.
Mark Koons
