Dust Collection
Subject: Re: Shapers
Shapers
10/20/13
John
I am looking for a high HP shaper. I have looked at Martin and SCM, are there any others that I should be looking at? I want a long bed shaper for profiling stiles for doors.
10/21/13       #2: Shapers ...
Max Neu
I have a Martin shaper that I use an Aigner extension table on,I am very happy with it.
10/21/13       #3: Shapers ...
JeffD
Those are probably 2 of the best shaper manufacturers out there so your starting at the top. If you want you can certainly work your way down as there are plenty of companies out there making shapers. But if you can afford a Martin or SCM you'll be in good shape!
Now having said that, if your just setting it up to do one thing, "profiling stiles", than any large industrial shaper should be fine for doing that all day long. You could pick up an old American made shaper for next to nothing that'll do that all day every day without breaking a sweat. Where the Euro machines win IMO is flexibility in being able to change from one operation to another quickly and accurately.
good luck,
JeffD
10/21/13       #4: Shapers ...
JR Rutter Member
I have a friend with a big Gomad (Polish) who really likes it.
11/11/13       #5: Shapers ...
I also have a big Gomad tilt that has been good. It weighs almost 1000kg! I can balance a nickel on edge, on it's table, while it is working. You don't see many of them around. Polish made.
11/12/13       #6: Shapers ...
Kevin Member
Website: http://www.bayerleinenterprise.com
I have (2) 130 class shapers from SCMI,
Quick change spindles are nice
Dotul sells a (Unique style) machine with stacked 40mm spindle. If I were only doing the same thing over and over I would definitely consider the Dotul
Dotul
12/7/13       #7: Shapers ...
David Kumm
A standard T130 with a feeder and extension tables that can be removed would work well. Here is one I found, redid the bearings and will likely sell. A good feeder is a must and if you plan to do vertical profiles against the fence, look at new Wegoma or used Elu or older Steff Primomatic if you can find one. Old Gomad were good shapers as has been stated. Dave
