Dust Collection
Subject: Re: Calculating FPM
Calculating FPM
12/10/13
James Member
I am designing a dust collection system. I have a dust collector with 6700 cfm. I am hooking up a notching machine and 4 sanding tables to the branch lines of the system. I am curious and asked by my supervisor to calculate the cfm/fpm at the end of a branch line. I have all my duct sizes and lineal footage and all. Can you calculate where I have 6700 cfm at one end the the pull of air it will have at the other end?
12/11/13       #2: Calculating FPM ...
Curt Corum
James,
At what level of resistance is the 6,700 cfm delivered at ? When designing a system, you must first determine how many branch runs will require simultaneous suction and add their volumes together. At a 4,000 feet per minute branch velocity, 4"=350cfm, 5"=550 cfm, 6"=785 cfm, 7"=1,100 cfm, and 8"=1,400 cfm. It is the amount of cfm in a pipe that creates the velocity. If blast gates are not allowed, you would add cfm of all branches for your cfm total. Then, the resistance of piping, etc., must be calculated. The dust collector must overcome the resistance (static pressure) and provide the required cfm for each open branch run. When calculating a dust collection system, the last thing we consider is the dust collector. Must first determine your requirements. Then, select the style and horse power that meets your requirements. There is additional equipment such as spark detection system and abort gate. If you need a device to check velocity on an existing system, you can purchase an Alnor Velometer.
Curt
