Dust Collection
Subject: Re: Replacing bags with canisters
1/13/16
Jeff M
Has anyone replaced their upper bags with pleated canister filters? I have the heavy 2 micron bags, but would like more protections from the super fine stuff. I have a grizzly 5 hp with the two big bags.
1/14/16       #2: Replacing bags with canisters ...
It would definitely be an improvement. Every time those bags pop out when you turn it on, it spreads the dust around. Be careful to size them correctly that you get enough air flow and don't choke the fan.
1/15/16       #3: Replacing bags with canisters ...
JeffD
You might be better off having an oversized bag made up by one of the filter companies. I have one of my smaller collectors that has a canister and I've never been able to keep it leak free or from clogging with dust. Personally I don't think that type of canister is a good solution for most small collectors and the more I've read up on them over time, the more I believe they're more hype and marketing than anything.
My main collector is a 7-1/2 hp Torit with 3 large bags. It only "needs" 2 but I added a 3rd to improve airflow and it works great for me.
good luck,
JeffD
1/18/16       #4: Replacing bags with canisters ...
Jerry Cunningham
I have....DON'T DO IT!!!! You will be sorely disappointed! The canisters work great for about 5 minutes, then they plug up. And they are a royal PIA to clean. The little flapper handle they give you doesn't do anything. As a matter of fact I'm putting my canister collector up for auction soon.
The best thing you can do is buy a quality filter bag from an American company, and get a much taller bag than what comes with the unit. I would go for at least a 72" tall bag.
Search on Amazon, AFF sells on there and you can get some good deals.
Jerry
1/18/16       #5: Replacing bags with canisters ...
Jerry,
You need to research a Thien baffle. Works great under a canister.
1/26/16       #6: Replacing bags with canisters ...
JR Rutter Member
Website: http://harmonicdesignworks.com
I will throw in my $0.02 for oversized bags rather than canisters as well. I've had both and going to more cloth area on a good quality fabric is better, IMHO. The cartridges start out great, but eventually will clog the pores and you are back to inadequate pickup and more dust in the air. I have even had large cartridges blow up when the pressure got too high from being clogged (with a high pressure fan).
1/26/16       #7: Replacing bags with canisters ...
Jerry Cunningham
A cyclone separator won't make any difference with a cartridge filter. It's the tiny particles that clog it, not the big particles the cyclone would in theory remove. If you go with a cartridge you will need pulse jet air cleaning every 15 seconds.
1/26/16       #8: Replacing bags with canisters ...
Jeff M
Thanks for the help guys. Looks like I'll be keeping the bags. I do have the really thick ones and they're about 6' tall, I think they're rated for 2 microns. They seem to work ok, but I'm just trying to be proactive about this superfine dust that I read about.
1/26/16       #9: Replacing bags with canisters ...
Jerry Cunningham
The replacement bags I bought from AFF weren't anywhere near as thick as the imported bags that came with the unit was. However it works much better. A good quality domestically made filter bag will be the same exact filter material that they use in the expensive baghouses. If the material is too thick it will restrict your airflow and add a lot static pressure to your system.
4/19/16       #10: Replacing bags with canisters ...
B.H. Davis  Member
Website: http://www.curvedmouldings.com
Last year I replace our Oneida 6' tall pleated canister with a tube sock system using American Filter Fabric tubes. The cartridge was a pain from day one. We would spend half an hour cleaning it once every week or two. Messy job that no one liked doing. Over time the pleats became embedded with dust that would not clean out.
The American Filter Fabric tube system uses 8 filter tubes that are about 6" diameter by 7' long, and all 8 tubes fit in a 24" x 24" foot print. There is a 24" x 24" x 24" manifold box at the top and a 24" x 24" x 12" collection box at the bottom.
The overall filter surface is much greater than the cartridge pleated surface and has yet to require cleaning. We have ZERO minutes in cleaning the system to date. We do empty the dust catch bin at the bottom of of the tubes once a month. It takes about 5 minutes.
The great thing about the American Filter Fabric material is that it naturally slakes off the build up on the inside of the bags. When the system is running the bags remain soft and flexible just like our oversize AFF bags on the smaller dedicated collectors on our two sanders.
9/17/19       #11: Replacing bags with canisters ...
CleanAir707 Member
Pleated canisters filters are much more efficient and less messy than bag filters. Even though they are a bit more expensive, they are worth it. You might try looking around on YouTube. There are tons of tutorials that explain how to upgrade from a bag to a canister/cartridge.
~Kaitlyn
(www.efisales.com
