Dust Collection
Subject: Re: More Baghouse filter area = more pipe velocity?
2/24/17
ALL other things held constant - Would having more total m2 of filter cloth area be better than less? i.e. diameter of pipe from machines to baghouse the same, diameter pipe to blower to the same, blower and motor same size.
FUNCTIONALLY SPEAKING - would the velocity of the air in the pipe from our woodworking machines to the baghouse be greater during actual use because with more m2 of filter cloth there is less resistance (i.e. more total m2 of microscopic air holes for air to pass thru the filters), and at any one instant, less partially plugged filter cloth before the pulse cleans it?
I know that TECHNICALLY (sorry for caps, there is no italics available!) the air velocity in the pipe is purely a function of pipe diameter and the fan speed (and motor size to maintain the speed at load), but I'm wondering if functionally more filter area will help maintain the theoretical velocity capability of the fan, motor and pipe diameter.
2/25/17       #2: More Baghouse filter area = more pi ...
JR Rutter Member
Yes, IF the filters are a restriction (not the fan or piping) then increasing filter area will move more air, giving higher velocity.
2/25/17       #3: More Baghouse filter area = more pi ...
Is there a formula or rule of thumb for how much filter area per HP of fan?
2/25/17       #4: More Baghouse filter area = more pi ...
JR Rutter Member
HP is misleading. You want to know the fan curve, which will show you the CFM at different static pressures. Static pressure includes the resistance of the piping ahead of the fan, and the filter area after the fan. Try to get the air to cloth ratio under 10:1.
2/26/17       #5: More Baghouse filter area = more pi ...
Thanks JR,
Our system is a "pull" vacuum system where the fan is AFTER the baghouse, pulling the air thru it. You seem to be describing a "push" system where the fan handles the dirty air and pushes it thru the baghouse.
Does that change your answer in any way?
2/26/17       #6: More Baghouse filter area = more pi ...
JR Rutter Member
No, same net result.
