Dust Collection
Subject: Re: motor upgrade on dust collector
11/21/17
john Member
I am looking to put a new motor on my dust collector to go from 20HP to 25HP to get the proper CFM to run my wide belt sander. It is basically to cut on costs of buying a new or used unit, and having to sell my old one. Is this possible? Any pitfalls I should be aware of ? Thanks
11/21/17       #2: motor upgrade on dust collector ...
How is that going to increase the cfm?
If the motor is the same rpm there will be no change. A bigger collector has a bigger wheel which needs a bigger motor to turn it at speed.
I am no expert but that is my understanding.
11/22/17       #3: motor upgrade on dust collector ...
Curt Corum
John, In addition to Bill's correct post, lets say you did purchase a larger horse power blower and housing, the square footage of filter on your existing dust collector would be quite undersized. Also, if there is a cyclone involved and you move more CFM than it is sized for, the resistance in the cone will be through the roof. Cyclones are sized for a maximum amount of CFM. Curt
11/22/17       #4: motor upgrade on dust collector ...
Gary
I used to have a 20 hp Torit cyclone that was 36" in diam. Torrit told me the cyclone was good for up to 30 hp. It was belt driven so with the increase of hp the pulley diams. would be changed to spin the fan faster to make more cfm. I believe the baghouse was also designed to add extra capacity by adding onto the top plenum and add more bags, four bags per section.
