Dust Collection
Subject: Re: How much CFM
How much CFM
11/22/17
Brian Member
I am moving into a new location and I’m going to lose my current dust collector that is a whole building system with the hopper outside. A big system like that isn’t in my budget. My question is, how do I figure how much air flow I need? Most of my saws can be taken care of with point of use dust collectors, but my CNC and Edgebander will need a better vacuum to keep them clean. I have the router and bander close to each other so I am toying with the idea of running them on the same collector I’m just not sure how much air flow I need.
We pretty much cut melamine, particle board, and Laminate sheet goods.
11/23/17       #2: How much CFM ...
You need to layout the machinery in the building including the collector. After that I call American Blower where I buy all my ducting and they lay it out and dictate the cfm. There must be a vendor like that near you. Second the equipment dealer who sells you the collector (if you are going new) can help. If buying used an equipment dealer you have a relationship with could probably help or guide you to someone who can.
Good luck!
11/27/17       #3: How much CFM ...
I have used Oneida Air for several systems since 1990. Send them a layout with the CFM of each machine listed on the layout, and they can price a new system, recommend fan size, hp, duct sizes, etc.
They always work very well, no after modifications needed.
