Dust Collection
Subject: Re: Dust Collector Upgrade vs. Add On
2/26/18
Jay Hicks Member
Hi,
Our Current dust collector of 15000cfm is under capacity. Can anybody give me the pros and cons of replacing the system completely with one unit vs. adding a second unit.
Summary One Unit vs. Two
2/26/18       #2: Dust Collector Upgrade vs. Add On ...
Interesting question.
I have questions.
Are you collecting man made panel dust, hardwood dust or both?
What do you do with the waste?
Are some applications infrequent?
Could you put an eco gate on your current system and not add capacity?
2/26/18       #3: Dust Collector Upgrade vs. Add On ...
Jay Hicks Member
We collect both. We have expanded into an area which will be mostly sheet-stock and currently has no dust collection.
Waste is currently blown into a 40 yard closed container.
Applications vary depending on the projects on the floor. Unpredictable.
I don't know what an ecogate is but I will inform myself.
Thanks for the reply.
2/27/18       #4: Dust Collector Upgrade vs. Add On ...
Jerry
Which part of your 15000 cfm is too small....the fan or the filter media? If you have enough filter capacity (maintain an acceptable air:cloth ratio) then it would be better to just add a second fan. Two 50HP fans will provide your with much more airflow than one 100HP fan.
2/28/18       #6: Dust Collector Upgrade vs. Add On ...
Jay Hicks Member
we are told it is limited by "fan throughput. the air velocities in the ducts do not reach those desired".
2/28/18       #7: Dust Collector Upgrade vs. Add On ...
I'll start this by saying I am no expert.
I am not sure what you said answers the question.
If you take a well designed system and add a duct here and add a duct there.... the velocity in the ducts start getting slower and slower. As the velocity drops below an acceptable level the collection falls off and dust can settle on the bottom of the duct and then you start to have all kinds of problems.
If you close too many ducts you reduce velocity and the ability if the collector to work.
So limiting factors are fan capacity (ability to breath in) and filter capacity (ability to breath out).
If your bags do not breath the system will not be able to hit its design capacity. Dust bag/filters do not last forever. They need to be replaced at some point. Do you have a magnehelic gage on the collector? I believe it tells the pressure differential from one side of the filters to the other. When it gets too high and cleaning will no longer make it come down it is time to replace the filters.
From your velocity comment it sounds like you got someone in to look at your system? In past systems I have found when we start to add things, eliminate things, close ducts it becomes a mess. If I was in your situation the first things I would do is make sure what I have is designed correctly.
Take a drawing of your machinery needs (duct size) and location and give it to a competent designer and see what they say. You might further define what is "on" all day and what is very intermittent. They may be able to fix the problem with a good design and some automatic gates of some type. Eco gate is an automatic gate system and a fan control system. There are other more basic systems that use an electro-pneumatic valve that triggers the gate using voltage from the starter control circuit.
I put a link to a company I use to design systems and they sell gates. They happen to be local to me so I am very lucky.
On that page they have the most basic automatic gates. Call for a quote, the listed prices I have found are not what you pay.
If you have totally outgrown your system, the filters/bags are good you come to the one system or two question but I would do the research first its "free".
Pneumatic gates
2/28/18       #8: Dust Collector Upgrade vs. Add On ...
If you were told air velocities do not reach desired numbers, get an engineer or a quality dust collection company to do an air flow study. Ducts may simply the wrong size. We were told to keep some gates open 100% of the time to keep velocity up in some branches.
